will this work?
hansk
1 hifonics BXI 2010d amp
Specs:
RMS Power Output: 1 x 650 W @ 4
RMS Power Output: 1 x 1300 W @ 2
RMS Power Output: 1 x 2000 W @ 1
Protection: DC, Speaker Short, Thermal, Overload
Power Supply MOSFET
Audio Output MOSFET
Dampening Factor: >250
Signal To Noise Ratio (A-weighted): >95dB
Variable Input Level Control (unbalanced): 0.2V - 9V
Input Level Control (balanced): 0.04V - 18V
Input Impedance (un-balanced): 47k-Ohm
Input Impedance (balanced): 20k-Ohm
Power / Diagnostic L.E.D.
Variable Low Pass Filter / 24dB: 35Hz - 250Hz
Variable Subsonic Filter / 24dB: 15Hz - 35Hz
Variable Bass EQ: 0dB - +10dB
Phase Shift (0 - +180 degrees)
Unbalanced Inputs (RCA)
Balanced Inputs (DIN)
Line Output (RCA)
Speaker Terminals (molded): 12ga
Power/Ground Terminals (molded): 0ga
Remote Bass Module: HFR-3
Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
Balanced line input for MX accessories and line drivers
Bass Remote included
Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
Dimensions 14.17" x 2.52" x 9.45"
with 2 Kicker L7 15" dual 4 ohm
specs:
Kicker Solo-Baric L7 Series
15" subwoofer with dual 4-ohm voice coils
SoloKon aluminum-treated composite cone with Santoprene surround
Cast-aluminum basket
Power range: 50-1000 RMS watts
Peak power: 2000 watts
Frequency range: 18-100 Hz
Sensitivity: 88.5 dB
Mounting depth: 8-3/16"
Sealed box volume: 1.5-6.00 cubic feet
Ported box volume: 3.0-6.0 cu. ft.
ok cause i was talking to a guy from a car audio shop and he said u would be better with a little bigger amp and needing a ho alt with this... is that true...??
I would recommend it. And an extra battery.
i was gonna do the extra battery but he also said that if your not gonna be running it for a long time at idle the theres really no need for the xtra batt
well, those Brutus amps are by no means sundowns, but they will push some power. Its kind of a good match in a way, L7 sound like shit and just get loud, and Hifonics throw sloppy watts...So, will you be pounding? Yes. Will it sound great? No
hansk
hansk
ATL
kr15
