CONNECTED 3 4OHM DVC into 2 channel amp problem! HELP!
defdaboss
this is what i have now. im currently using 4 pioneer premier 12" 4OHM DVC model TS-w3001D4
1000 watts rms 3,000 watts max.
i have a performance teknique GIANT amp
# Power Output @ 14.4VDC
* MAX Output : 5000W
* RMS Output @ 4 Ohm : 600W x 2
* RMS Output @ 2 Ohm : 900W x 2
* RMS Output @ 1 Ohm : 1100w x 2
* RMS Output Bridged @ 2 Ohm : 1800W x 2
as you can see. at the end it says bridged @ 2ohm 1,800 watts x2 (i currently have 3 not 2)
is this the reason why my amp keep shuttin off when i raise the volume?
It should probably say
* RMS Output Bridged @ 4 Ohm : 1800W x 1
It's probably only stable at 4 ohm bridged, and you're going down to 2.67.
defdaboss
defdaboss
DADE
kr15
