Will this sound good???
AudioPLaya368
Hey guys put together this together havent gotten it yet but paid for it.
1 KX2500.1 MONO AMP
2500 WATT MONO AMP
Fan Cooling
Radically Advanced Chassis with Removable Chassis Shroud
Short Circuit, Over-Voltage, Reverse Polarity, Thermal (SORT) Protection
Efficient Class D Circuitry
Remote Bass Boost Control
KickBass 0-18 dB Variable Bass Boost at 40 Hz
12 dB / Octave Low-Pass Crossover
Defeatable 12 dB / Octave 25Hz Subsonic Filter
Variable Crossover Frequency from 50-200 Hz
PreAmp Signal Transfer (PAST) Output RCA Jack
Delayed Turn-Off Logic Circuit
Soft Start Turn-On Circuit for Reduced Startup Load
powering..
2 KICKER SOLOX 12's S12X S12X2 SUBWOOFERS
Model : S12X2
Size (IN., CM) : 12, 30.5
Impedance (OHMS) : 2 DVC
Max Rec Amplifier Power (WATTS PEAK) : 5000
Max Rec Amplifier Power (WATTS RMS) : 2500
Sensitivity (dB 1W/1M) : 87.7
Frequency Response (HZ) : 20-100
Mounting Depth (IN., CM) : 8-9/16, 21.7
Mounting Cutout, Square (IN., CM) : 11-1/4, 28.6
Recommended Box Volumes: The SoloX is engineered for highly specialized installations/applications.
Let me know what else I am going to need as well as will I need a yellow top with this do you think its a good idea. cap? ehhh Let me know guys your help would be much appreciated.
wait wait your getting 2 solox's off of 1 2500? cant like 1 solox alone take 2500 ?
I was thinking that as well...maybe this is all the assaulting his checkbook can stand for this time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
from what I've read up on the solo x's they seem to do some major damage, 2 would just be unneccesary, if you can install one right and give it enough power, you'll just fine, trust me!
no one saw my first post //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
anyways...I think youll be fine with one solo-x ported
Dude, STFu, I have triple, almost qudruple your posts and no one ever notices what I say.
I saw your first post //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif and yeah as I said one will be fine and obviously ported
AudioPLaya368
AudioPLaya368
los angelos CA
Jay_Rich
vegang
vegang
