do_dirty
Im trying to put together the loudest spl system possible with limited funds. Im working with around 1K and limited trunk space. (W 40'' /H 18" / Depth 24-35'' or so. Im trying to fit it in the space under my back dash in a 98 Deville. I have 2 12'' that fit perfectly under it now and I still can use my trunk. This box seems to be perfect but the subs are so new I cant find any specs. This is what Ive put together. Any sugesstions?
---4 12'' PW3 SERIES COMMON FEATURES
Dual 2 ohm voice coil
PP Injection molded dome cone
Laser etched tattoo design on cone
Stamped steel basket
Durable wrinkle finish
ABS plastic motor cover
Foam surround
ABS plastic gasket
Dual CONEX spiders
Integrated tinsel leads
Nickel plated push terminals
PW3-12H SUBWOOFER SPECIFIC FEATURES
2400 Watts power handling
800 Watts RMS
140 oz Magnet
2.5" BASV Aluminum Voice Coil
Mounting Depth: 6.25"
Power Acoustik Ps1-5500d Class D Power Series Mono Amplifier [5500-watt] Ps15500d
Description back to top
4? Rms: 1700w
2? Rms: 2500w
Mono Rms: 3200w
Mono Max: 5500w
High-speed Digital Circuitry
Full Regulated Pwm Power Supply
4-way Protection Circuit
1? Stable
Bridging Synchronization
Variable Low Pass 50 Hz150 Hz
Variable Subsonic Filter 15 Hz40 Hz
Variable Subwoofer Eq @ 45 Hz
Phase Switch 0-180
Remote Dash Mount Low Level Gain Control With Cable
Freq Resp: 15 Hz To 150 Hz
S/n Ratio: 100 Db
Thd: 0.5%
System Distress Indicator
input Sensitivity: 200mv8v
dual Mono Speaker Output Connectors
platinum-plated Heavy-duty Power & Speaker Terminals
I believe the box has 2 chambers with 2.1 cubic feet each.
Foam surround
ABS plastic gasket
Dual CONEX spiders
800 Watts RMS
140 oz Magnet
4? Rms: 1700w
2? Rms: 2500w
Mono Rms: 3200w
Mono Max: 5500w
1? Stable
Phase Switch 0-180
S/n Ratio: 100 Db
Thd: 0.5%
