Will this be enough??
Shadow7874
Atl
I was looking at the damplifier pro and a Bulk Pack - 36.50 sq feet costs $159.87
I can spend the 160 without worrying to much as long as its enough for a good bit of deadening. Im wanting to do atleast one layer on my floor doors trunk firewall and just where ever i can. How far will this go if i only do one layer for now?
Also how thick is damplifier pro? I think it said 50% thicked then damplifier which is 1.5mm so i guess its 2.25 mm?
I wont have problems when reinstalling carpet from the thickness will i?
well you have 36.50 sq. feet to work with. maybe you can do a little measuring to get an estimate for what you need.
also when you do start deadening your car, cover all the large flat areas first, then with whats left over hit the curves.
I was looking at the damplifier pro and a Bulk Pack - 36.50 sq feet costs $159.87I can spend the 160 without worrying to much as long as its enough for a good bit of deadening. Im wanting to do atleast one layer on my floor doors trunk firewall and just where ever i can. How far will this go if i only do one layer for now?
Damplifier pro has a foil that is 50% thicker than regualr damplifier and 30% more adhesive by weight.
You will have no problem puttin ght ecapet back in place..
ANT
Shadow7874
Shadow7874
Atl
atsaubrey
