I think this is what ur sub will be getting "RMS Power 350 watts x 1 channel @4ohms.just fixed it
yeah sorry bout that, I jumped the gun on that one.Thanx I was just wondering if those stats were real.
I believe u can do this since the amp is 1 ohm stable.The Pioneer sub has dual 2-ohm coils -- wire in parallel for a 1-ohm load and it will work just fine with that amp.
so that amp has to be 0.5 ohm stable and u need to wire your 2 subs parralel?Yes the amp will power that sub just fine.
Where do you see him talking about running a pair of subs? I see mention of one sub and one amp. If he only plans to get one sub, then the amp will work just fine.so that amp has to be 0.5 ohm stable and u need to wire your 2 subs parralel?
