Will this amp and speakers go together?
Grathan
Blaupunkt THw 1200
http://www.dealercostcaraudio.com/thw1200.aspx
4 ohm, 200RMS 600 peak
Blaupunkt THA2125 Two-channel Amplifier
http://www.shipsound.com/product_info.php?products_id=100382
125 watts RMS x 2 at 4 ohms (200 watts RMS x 2 at 2 ohms)
200x2 W RMS @ 2ohms
350 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
MINIMUM SPEAKER IMPEDANCE Non-bridged: 2ohms / Bridged: 4ohms
I have 2 speakers and 1 amp on order. Can these be wired correctly?
For some reason I am thinking bridged to parallel speakers..
Also what gauge wire would an amp like this require for +/- ?
So 4 gauge it is. thanks!
I have to make an enclosure for the speakers. I would like to have them both in the same box.
Is it better soundwise to have a seperator wall between the 2 speakers inside of the box, or just leave it all open?
I would like to have only 1 set of wires going to the box. Can I just bridge the amp and wire the speakers in series?
Is there any way to make a quick clamp that locks the box in place in the hatch to make it easy to take in and out?
Grathan
Grathan
Albany NY
Grathan
