Will they fit in a 04 Monte Carlo
DocisChief
Illinois
Anyone with an 04 Monte Carlo or one of those approximate years know if you can fit 2 15's ported in the trunk. I might be getting one and I've been planning out my next system and had my mind set on 2 AQ HDC315s. I know at minimum they need like 4 cubic feet a piece so I'd need 8 net to work with. I'd also like to have them not firing up if possible. Thanks guys.
im not familiar with specific dimensions of the car, but 8 cubes + port volume is going to be snug, but the trunk is pretty large and has a pretty large opening, you may have to build the box in the car
^^I said I don't have the car yet, but I might be getting one. I tried searching for the dimensions, and I can't seem to find them. I just get that "cargo area is 15.8 cubic feet" or roughly. I don't know how that's distributed dimensions wise though.
Like i said, it should fit, but you may have to build the box in the car. and you should be able to make the subs face front or back
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
DocisChief
DocisChief
Illinois
BlactimusCrime
Decebal
    Jun 10, 2024
