Will subs fit?
The XS-L121P5’s unique five sided polypropylene cone not only looks cool but is stiffer than conventional round cones for lower distortion and higher power handling. The solid construction P5 center cap adds additional strength to the cone assembly and looks cool too! The unique foamed rubber surround with stroke stabilizers and double damper suspension ensures distortion free bass response, even at "wake up the entire neighborhood" volume levels. The P5’s unique basket design allows the woofer to mounts in regular round woofer holes.
I wouldnt buy either one but I believe they will fit but that box is to small it's .77 internal space cubed on each side and you need at least 1 cubed for each of those subs sealed. and with the displacement for the sub the boxes internal volume will be even smaller.
x2, dont buy either one. Look into getting a good pair of 12's and build your own enclosure.
Im actually on a 200 doller budget, and this is a upgrade from what im running now (walmart sonys) and really POS box. But thats all i needed to know. Just making sure they would fit.
dont replace crap with crap. Save your money and buy something good. What amp do you have. There are better subs. Just buy 1 good 12 and build your own enclosure..
Ok bud. Look around on here for a better sub, You can find a good sub for 100-150 and then have a box built for you
or you know what, it's your money spend it how you want. Im sure those crappy subs will fit in that crappy box.
You already have a decent amp. $200 is plenty for a decent sub, and materials to build your own box. Those Sonys are horrible- I had them before.....DEFINITELY go with the ID subs linked above, youll be much, much happier, if you go with them instead of the sonys.
Or, you could just get one sub, rather than the two sonys.....
the realll question is not if the subs will fit in the box......its if the box will fit in the carrr.......//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
pd298
pd298
oklahoma
pd298
vegang
vegang
