Will one extra battery in my trunk handle this?
scottyk
lil' nig
344
NY
Here's my question. I'm gonna be running 2 DD 1508's on an AQ 2200D. I currently have a stock battery under my hood and an optima redtop in the trunk. I know this alone won't cause much need for electrical upgrades (will do the big 3 but not looking to buy a HO alt) but I also want to invest in some nice speakers for up front and run them off a decent size amp. Would the stress of the amp for my speakers plus the 2200D on just the stock battery up front and the optima be a little too much?
If so, would you guys suggest me taking the optima and throwing it under my hood and getting something like a Kinetik hc600 to put in the trunk so I still have two batteries but both are after stock?
i have a ranger with big 3 done in 1/0 with two rhino 800 batts in the back with 2k rms and i drop to 13.8 full titlt at idle. yes u will need a batt but something bigger than the 600..... go big now that way when u upgrade u wont have to upgrade ur batts that much
OVERKILL
There are plenty of people running 1508's on 1k each. And I do have such a thing as a gain knob, never said I was going to crank it.
So will my stock alternator be ok with charging up a big battery like the hc1800 then? I don't want to invest in somethin as big as the 2400, but an 1800 and the optima up front will be ok?
For insight, I have 2 batteries ONLY, a blue top optima as my main, and a large REGULAR g34 battery, biggest one I could buy at the local auto place, 105ah 160min reserve, just a regular $110 battery on sale though, running my ~4000rms stereo, I dont drop below 12 volts on full tilt.
BEFORE I added the g34 and was just running the optima, I was hitting high 10's, just to show you how much a second bigger reserve battery makes a difference, and Im running quite a bit of power
I have no experience with Kinetiks and such though
Interesting. I was investgating the Kinetik's. The HC1800 I found for $200. I may try to get a used one on here. Anyone got any other suggestions for a battery? assuming the redtop goes under the hood?
red top underhood, hc1800 in trunk and you'll be good.
You dont' want the redtop in the trunk, it's a not a good deep cycle battery.
I run 1800 off a hc1800 underhood, and hc600 in the trunk. Drop to about 12.6 w/stock 80amp alt.
scottyk
lil' nig
scottyk
NY
7ender
