will amp make highs louder
get a different amp for your highs. if you plan on running any door speakers to an amp, get new speakers. the ones from the factory are garbage paper products lol. youll blow them, id get a new air of door speaker and a seperate amp for them.
You fit two L7 15's in your trunk? As for highs, grab a set of pods for your kick panel and run a component set. A decent 150x2 amp on a respectable set will keep up with a loud sub stage. Check out the PHD vendor forum here fur a nice set, too.
Now that you mention it, OP how big is your box, and what is it tuned to? I think pods might be above what he is looking for, but OP that wouldn't be bad. Highly dependent on the drivers you choose though. Some drivers like ported, others small sealed. Same as subwoofers.
[quote name='gckless']Yes. Best thing to do is get a component set that will fit and power them with an amp. But new 4x6's with an amp will make a big difference too. @mylows10 what can you do for him?[/QUOTE]
depends on the power he wants to run and 4x6 speakers as well. i's make or buy adapters and run components there instead
tyronekndrck
tyronekndrck
cincinnati oh
mylows10
