Will a Kicker 2500 work on a btl?
shortyg83
Ok so I have a 15" inch dual 2 ohm btl which means It will be running around 1 ohm. Box rise and such will put it closer to 2 ohms. I have an oppertunity to get a kicker 2500 cheap but it doesn't say it is stable at 1 ohm. Does anyone know if these will run at 1 ohm or not?
people have had success running the zx2500 at 1ohm with proper electrical system, meaning keeping a stable 14voltage or close to it atleast.
^^ like said above but remember this amp will draw upto 300amps so if your going to run it at 1ohm you better be able to power this thing. Ian running mine at 1.4 but after impedence rise the amp is looking at about 2.2ohms which i think is right in its sweet spot. I have a 135a alternator big 3 and a yellow top g31 in the back w 1/0 ga wire and the voltage goes from 14.4 down to 11.00 //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
shortyg83
shortyg83
pa
BassAddictJ
