Will 4 awg work for this....
The Item in the Picture on Ebay
Better Safe than Sorry my friend. This would get ride of your headache and its not that much like 8 bucks. Hope I helped some.
If you don't understand there is a current limitation on any given size of wire - regardless of length or voltage you shouldn't be trying to contribute to the discussion.
Since you're so smart -- take yourself a piece of 4 ga wire just long enough to reach from the (+) terminal of your battery to the (-)
According to your implication a 2' piece of 4 ga can safely conduct 900A+ so a ~1' piece should have no problem at all conducting the few hundred amps your battery can put out, right?
Do that and let us know how it goes.
**Disclaimer: N2audio is not responsible for electrical and/or chemical burns to dumb people.**
Let me restate my position...
Will a short piece of 4 ga to an efficient 2200w amp "work"?
Probably. IF you're listening to MUSIC, and listening at moderate levels. Under those conditions the current draw should be within the limits of 4 ga.
HOWEVER - an amp capable of 175-200A of current draw during high volume test tone burps most definitely would be capable of heating up 4 ga wire, and you WOULD be risking a fire. Fuse at 125A and you should be safe, but this is an amp worth more than 1/2 as much as my car. Why would you go cheap on a 2' piece of wire?
rc10mike
I b sippin on sizzurp
rc10mike
Jacksonville, Fl
ahillworks
BP1Fanatic
BP1Fanatic
