found this on another forum
Letter from JL
Here is the reply I received from JL Audio when I asked why the owner's manual reccommended a short ground to the chassis and the installer was referred otherwise;
Mike,
Thank you for your interest in JL Audio. In the owners manual, you are going to find a recommendation to have the ground as short as possible. This can be done with most vehicle and most audio amplifiers. You can run a ground wire back to the battery. This can be better then grounding to the chassis of a vehicle. As long as the ground wire is as large as the positive wire, there is no problem.
We have done some testing on all different vehicles. This test was to measure the resistance of frames and uni-body constructed vehicles. The best are the vehicles that have a true frame rail, like your Suburban. You want the ground wire from the amps to be mounted to the frame. You also want to upgrade the factory ground return wire. This runs from the negative side of the battery to the frame. Now the best results only equaled the same resistance as a 4awg wire. Uni-bodies are like an 8awg.
This installer made sure that the ground return of the amplifiers do have the least amount of resistance. This preventing any type of voltage choke.
There is no problem doing this. As long as it is done correct. In this case, I am assuming it was.
