audioholic
not a moderator
Even the person credited with inventing the idea of adding caps to a car audio system does not agree with your assessment. He (Richard Clark) has further stated that even the reasoning he did it, for power conditioning, is generally not necessary unless you are competing on an extremely high level SQ basis, as he was at the time. At that level, every little pop or noise added to the sound can make or break you, and even having judges simply SEE a cap (or better yet, a bank of small ones) in the system can add points to your score by way of simple human perceptions of reality.I can't say that it WILL, but in most cases it does. There are a few variables to take into account, one being in the nature of his grounds, which has been stated by someone else. Every install I've done that the lights have dimmed, whether it's my own ride, a friends, or a customers, it has fixed the issue. The size of the alt does come into play on some. An 85 ampere alt w/a 250 ampere system, a cap wont fix that issue. So there are some variables to take into account.
If your charging system is sufficient to power the current demand placed on it, but your lights still dim, you have a resistance problem that a cap merely masks. If your charging system is insufficient to power the current demand placed on it, adding a small capacity power supply will not change this, no matter what its discharge rate is.
Furthermore, do you realize your amplifier already has a bank of capacitors built into its input stage? So, if more capacitance is required for proper audio performance, why do you suppose all the amp manufacturers out there dont just build more capacitance into their input stages?
If the root reason for adding a cap to your stereo is to prevent headlights from dimming, you'll be money ahead by simply adding small caps to your headlight circuit. But that would be kind of silly, wouldn't it?
