why does this not work
kingbrew06
Size 10 -inch MTX BLUE THUNDER RAN THREE ON THIS AMP
Impedance 4 ohms
Cone Material Polypropylene
Surround Material EPDM rubber
Sealed Box Volume (cubic feet) 0.5 - 1
Ported Box Volume (cubic feet) 1 - 2
Port diameter (inches) 3
Port length (inches) 10.75
Free-Air No
Dual Voice Coil No
Sensitivity 85 dB at 1 volt
Frequency Response 37 - 150 Hz
RMS Power Range (Watts) 75-250
Peak Power Handling (Watts) 500
Top Mount Depth (inches) 5 1/16
Bottom Mount Depth (inches) 5 9/16
Cutout Diameter or Length (inches) 9 1/4
Vas (liters) 23.7
Fs (Hz) 37.6
Qts 0.67
Xmax (millimeters) 9.44
Parts Warranty 2 YEARS
Labor Warranty 2 YEARS
Size 10 -inch KICKER C10s CAN NOT RUN THREE whats the difference???
Impedance 4 ohms
Cone Material Polymineral
Surround Material Foam
Sealed Box Volume (cubic feet) 1 - 2.4
Ported Box Volume (cubic feet) 1.25 - 1.75
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air Yes
Dual Voice Coil No
Sensitivity 87.3 dB at 1 volt
Frequency Response 30 - 500 Hz
RMS Power Range (Watts) 50-150
Peak Power Handling (Watts) 300
Bottom Mount Depth (inches) N/A
Vas (liters) 64.38
Fs (Hz) 29.4
Qts 0.451
Xmax (millimeters) 9.76
Parts Warranty 1 Year
Labor Warranty
A one ohm stable amp to run three Dual4 subs at 300RMS a pop? Keep in mind with three subs the ohms get funny. If you do it in parallel on three subs then you dropped to 0.6666666ohms which is probably why the amp shut off.
Oh shit, C10's. Sorry man, I was thinking CVRs. Regardless you were dropping to 1.3333 then and it could still kill an amp in that situation. Or at least make 'er shut down.
I -think- most of the Hifonics Brutus amps are 1ohm stable, and seems like a lot of people like those (although they get some shit on the boards). Get the 1200watt one and since it's 900 at 2ohm and 1200 at 1ohm, if you keep the gains low that should be fine.
The MTXs are the same VC config, so its not a problem with the amp since he would have the same ohm load... my guess is he wired them wrong or turned the gain up too much
kingbrew06
kingbrew06
nashvile'tn
SRim23
