Why does speaker wire touching metal create gnarly screeching?
ckunke002
I installed some component speakers, but at the moment the speaker wire coming out of my xover for my tweeters isn't connected to the tweeters and is just hanging around. I noticed today that a couple times it bumped into my door (no door panel all metal) and all the speakers created an extreme piercing screech. What exactly causes this and what is happening when that occurs. Something with grounding i would imagine.
Could I have damaged my speakers/amp? Just wondering thanks
ur grounding ur outputs,common sence here. will put ur amp into protection or blow amp...
I realize that my outputs are contacting grounds, but didn't see the connection between that and make the rest of my channels scream.
dude you are grounding out your amp,you keep doing that you will blow that amp,your amp chassis is grounded,your speaker outputs are AC voltage and AC current,and you are letting that AC power touch a DC negative ground,so...........what do you think is going to happen???????????/
word. lol problem solved.
ckunke002
ckunke002
Portland, OR
ckunke002
michigan born
    May 14, 2026
michigan born
    May 14, 2026
