why does my dd 1510 sound like chit
OK ...i SEE YOUR AMP DOESN'T HAVE FULL RANGE...so you have to always use the built in crossover on the amp...try moving your RCA's to the rear outputs from your deck...instead of sub out put ... .then make sure you turn off the hpf in the deck and try that...set the amp crossover at 90-100hz...subsonic at 25hz
Can't thank you enough its way better. I really appreciate all your help dave!! Cured almost all problems except has some hard slaps here n there maybe once it breaks n more it won't idk?
Wow, I have that same issue with my 1508's. I'd just assumed I'd burned the VC's because to be honest, I beat the shit out of them with no loading wall just to see what they'd do. I was about to send them back to DD to be reconed since I've got my loading wall setup now.
HOWEVER, I just noticed you're also running the Pioneer 4100DVD. I'm going to move the RCA's to my rear output as well, to see if it makes a difference. I doubt it will, knowing what I put those subs through, but you never know. What you described is exactly the sound I heard. Like the dust caps were rattling or something. Only when you turn it up loud.
Dunno if y'all care, but I'll post the results this afternoon.
o ya i care hey ill pm ya, but i havent beat the shit out of this sub . the amp clips the shit out of it before itll get loud!
the cause of all the problems lie at fault of the box designer mobeious. the sub works wonderful in a properly designed enclosure. stay away from mobeious designs theyll fuk yo chit up!!
How can you say that , you said what LACRX told you fixed all your problems and soundas wayy better
burzendowski
burzendowski
CA.COM
wilson
