Why does my amp cut off my sub at high volume?
alexdbest2000
this is my setup:
Kenwood bt852hd (2.5V pre-outs)
Alpine MRV-M500 amp (500 rms at 2 ohm)
Sundown SA-12 D4 sub
1 gauge wiring
To adjust gains I:
1) unplugged all speakers and sub
2) set all eq, bass boost, gain etc to 0
3) set LP filter to 80
4) played an 50 HZ track on repeat
5) connected DMM to sub +/- terminal on amp
5) turned gain up to meet voltage requirement (31.6)
6) had to turn gain almost to max...
Every time the sub hits hard at around 3/4 the volume the amp turns the sub off, while the amp stays on. The sub will only work after i shut the car off and then turn it back on, the amp is brand new. I dont think its a grounding problem, i drilled a hole in the chassis and grinded away any paint. Is it normal for the gain to be set that high? Is the amp going into protect mode? Why is it doing this? Am i missing something with tuning the amp?
this is where my gain is
May not help, since it seems to be setup correctly, but i would double check wiring from the inside of your sub enclosure to the amp it self, maybe even the wire to the HU and Batt. If all checks out good, maybe your amp, may to be looked at..?
alexdbest2000
alexdbest2000
NY/Canada
xxrcm619xx
