that sounds like a little too much?Didn't Richard Clark recommend something insane like 10x RMS power handling in order to have the best headroom situation? My only issue is I can't afford to provide 10x RMS power or the electrical upgrades required to support it![]()
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifwatts are like cowbells, you can never have enough.
About this clean signal stuff... what causes a signal to be dirty? If I were to clean my RCAs or optical cable with goo-gone or something, would I then have a cleaner signal?
the only decent and simple answer so far in this fail threadthink of it this way. say you have a 100 watt speaker and a 100 watt amp. at 99 watts, there will be more distortion using that 100 watt amp than if you used a 500 watt amp at 99 watts
less distortion = better sq
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
a decent and simple answer you couldn't provide.the only decent and simple answer so far in this fail thread
i'm pretty sure many would argue that the distortion you're talking about here is not an audible difference between the two amps.think of it this way. say you have a 100 watt speaker and a 100 watt amp. at 99 watts, there will be more distortion using that 100 watt amp than if you used a 500 watt amp at 99 watts
And those people would be wrong.i'm pretty sure many would argue that the distortion you're talking about here is not an audible difference between the two amps.
then how do you explain bullet tweeters that only need like 30W to get loud as all helmo power=mo better, what's so hard to understand about that?
efficiencythen how do you explain bullet tweeters that only need like 30W to get loud as all hel
Yes. Indefinitely.watts are like cowbells, you can never have enough.
Just because they get louder with less power, does NOT mean they sound better you fuck-tard...exactly... so power isnt everything
