bubbagumper6
My local hardware store sells hurricane nuts, and they're no more expensive than t-nuts. Why would I recommend an inferior product? The reason t-nuts don't require as precise of a hole is because they have much more 'give' to them, thus making them a much less secure connection...The suggested "fix" for the problem was using Hurricane nuts.....which are more expensive, harder to find, and require a more accurate hole to be drilled for threading in.
A simple T-Nut is only 15 cents or so at a local hardware store. A complete moron can install a T-Nut without even having to drill an accurate hole. A T-Nut will NOT pull through without considerable force and requires no threading into the wood. That is why a lot of speaker cabinet manufactures for Marshall, Ampeg, Carvin, etc use T-Nuts to hold in speakers on road worthy speaker cabs.
This forum is full of people who want to give advice, but they don't think about how easy it will be for a newbie to find the hardware/tools and be able to install it with zero troubles. Its like telling someone to buy a Time-Cert when they could just tap a hole to the next larger size.... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
EDIT: I was taught with the philosophy "If you don't make time to do it right the first time, you better make time to do it again" And as far as I'm concerned, hurricane nuts are the best long term option. I've used a lot of different mounting hardware over the years and nothing beats hurricane nuts in terms of longevity...
