crossfire puts out 1k @ 2ohm on 12v
That can't be right.. here's a some info i've found on it.
■Over the past decade Crossfire Car Audio has risen to the forefront of the amplifier market and dominated in the competition scene. In 2001 alone Crossfire's 1000D Amplifier single handedly brought home 37 trophies in 3 different sanctioning bodies, (including 19 in the top three), and the Db Drag Extreme Cup (for the highest SPL of the show). The all-new VR series amplifiers are the result of this success. Unrivaled performance, rock solid reliability, and a sleek new look, all provided to you at an affordable price, this is what Crossfire is all about.
■Military Spec, audiophile grade components: For exceptional sound quality, power output and reliability
■Full Mosfet PWM power supplies with Ultra efficient
■Multi-Stranded power torroids: At 86% efficiency Crossfire Class-D amplifiers are unparalleled!
■Built-in Continuously variable Highpass/ lowpass crossovers 50Hz to 250Hz (Input and Output): For system design versatility and cleaner signal paths.
■Built in "Bridging Module": The internal bridging module allows two like amplifiers to be run into one load.
■Continuously Variable Subsonic filter 20Hz to 50Hz: Helps protect a subwoofer from damaging frequencies
■Remote Subwoofer Level Control: Allows for accurate control of the subwoofer level from the drivers seat.
■High Current Class D subwoofer amplifier
■1 ohm stable
■Wired Bass Remote Included
■Tested Power: 1332 Watts RMS
■1000W x 1 at 1 ohm
■500W X 1 at 2 ohms
■250W x 1 RMS at 4 ohms
■Variable Subsonic Filter
■Variable Highpass/Lowpass Crossover from 50 to 500Hz
■Low level (RCA) inputs only
■MOSFET power supply
■Nickel plated connectors
■5 way protection circuits
■9.3"W x 2.1"H x 14.5" L
■This is an Open Box item, it has been thoroughly tested by Crossfire Electronics, and operates exactly as new.
■Warranty: 90 Day Limited
■Condition: Very Good, Minor cosmetic scratches.
■Reason for discount: Customer return
■Includes: All parts and accessories which accompany new Amplifier.
VR-1000D - Crossfire 1000 Watt Mono Amplifier VR 1000D
