Which subs would sound better?
brybry354
need some opinions/advice.
im looking to upgrade my system from some simple KickerComps 10" to some subs with more thump.
im buying Kicker and dont wanna spend more than 200 a piece for the subs...so i have these few in mind...and i have a sealed truck box with .55 box volume (i know its low)
http://www.sonicelectronix.com/item_17588_Kicker+09S10C2+-S10C2-.html
or
http://www.sonicelectronix.com/item_6504_Kicker+06S10L52+Solo-Baric+L5+Series.html
or cut 12" holes and put these in...http://www.sonicelectronix.com/item_8362_Kicker+07CVR122.html
keep in mind im using the same box...http://www.supercrewsound.com/commerce/product.jsp?prodId=214&catId=21
Both subs you mentioned above will sound awful in that box since it's not designed for them. That's the problem with prefab.
I doubt anything you do with that box will sound good, but given that, there are far too many factors to consider.
You need to find a pair of 10's that will do well in .55 sealed, don't try and upgrade to 12's or subs that require more air to work well. It's a waste of money and time and will likely sound worse.
okay thanks for the help.
yeah i know...prefab sucks but i would have no idea how to make a box to fit my truck.
so ill just stick with some 10" that have a low sealed air space
brybry354
brybry354
Texas
kevin lu
