Which Pick UP Trucks..
new tundra crewmax. tons of room in the rear. and they are made in the USA... chevy and GMC are made in mexico FYI
This. I have an 09 Crewmax 4x4 with the 5.7. Hertz HSK165s up front, Eclipse coaxials out back, Eclipse EA4200 and Alpine MRPM500 amps, Pioneer Premier 10 in a shallow box behind the seat.
It's got stock left, right, and center dash openings that look like they could take up to 3.5 inch drivers with few further mods if you find the right mounting depth. People who get in my backseat tell me they feel like they're in a limousine. The rear seat slides forward and backward and reclines. Right now my 10 in its custom shallow box from my old Dakota Quad Cab sits behind half that seat. I loose maybe 2 clicks of seat travel with the seat still reclined slightly, and from the front of the rear seatbottom to the rear seatback still looks like a football field when you open the door and look in.
2 tens behind the rear seats surely wouldn't be a problem, I imagine 12s could be managed too. The rear leg room is so cavernous from the get go you can give some up for a box and still be way ahead of a sedan as long as you don't go crazy on mounting depth. Im actually tempted to try my first normal sized 10 in a decent sized box in the same spot now that I have all this room to work with.
For bigger subs an extended cab version of anytruck is probably the way to go as there's usually more space for a box under the fold-up rear seat bottom you'll find in the back of most.
Can't see the vid here but I can probably guess which one it is. Alls I can say is don't believe any other manufacturer's hype and don't knock it till you try it.
09 Crewmax 4x4, 5.7 V8.
5600 pounds, 10,000 pound PLUS tow rating.
Don't care what the jiggly videos show, the last squat test I saw between the big 3 with a heavy trailer on the hitch the Tundra stayed closest to level with a 6500 pound trailer hooked up using no weight distribution setup.
Mine rides fine and owns almost everything stop light to stop light except for sports cars and the fastest sports sedans.
5600 pounds, 381 horses, 400 pounds of torque, and 18.7 mpg on my first long road trip with the cruise at 60-65 mpg.
Why would you want a ford with 70 few hp but the same mileage or a Ram with coil rear springs and less towing capacity instead.
ugs92
ugs92
Connecticut
eharri3
BP1Fanatic
BP1Fanatic
