Which OS amp to run?? Louisiana_CRX come on in. PG or Xtant
ace_800
So I've got a Xtant 3150x 3 channel coming from Orlando I picked up a couple months ago. I also can get ahold of a OS Phoenix Gold m44 locally. I'm not sure which one I should run and which I should sell.
I'm going to be running a set of kicker comps off the front channels and a D4 Trubass 8 in a T-line.
Specs for both amps(both underrated):
Xtant 3150x
2 x 25 + 1 x 100 @ 4 ohms
2 x 50 + 1 x 200 @ 2 ohms
So I'll be running 2 x 25 for the fronts and 200 @ 2 to the sub
PG m44
4 x 40W @ 4 ohms (12V)
4 x 55W @ 4 ohms (13.8V)
4 x 110W @ 2 ohms (13.8V)
2 x 160W @ 4 ohms bridged (13.8V)
So I'd 2 x 40 for the fronts and I would have to run 2 x 40-55 for the sub. I've seen its rated more at 75 per channel. Wish I could bridge the rears to 2 ohms.
Opinions???
I have heard and owned the older xtant line. Fragile amp too. That was 8 years or so back though. But most recently I have had both m44 and m100 at the same time. Shinju is the person to talk to about these. He played them for me before I took them in a trade. Caps are a problem area for them. May need to be replaced. M series is a great line though!
ace_800
ace_800
Okinawa, Japan
ace_800
