cleansoundzz
Which numbers are better, woofer #1 or woofer #2?
WOOFER #1
Impedance: 2-Ohm x 2
Power Handling: 600 Watts RMS
Max Power Handling: 1200 Watts
Voice Coil Diameter: 3" anodized aluminum
Motor Size: 102 oz. double stacked
Speaker Connector: Dual 8 AWG slot load
Fs(Hz): 35
Re(Ohms): 3.1
Le(mH): 3.0
Qts: 0.55
Qes: 0.60
Qms: 6.09
Vas(Liters): 15.8
Sd(cm2): 310
SPL(1w/1m): 82
Xmax(mm): 14
Woofer Displacement: 0.134 cu. ft.
Cutout Diameter: 9.125 in.
Mounting Depth: 6.25 in.
WOOFER #2
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
Electrical Q Value -Qes: .46
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: .42
Free Air Resonance -Fs: 26.6 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency - SPL 1W/1m: 83.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 2.8 ohm
Mounting Depth - 6”
Mounting Hole Diameter - 9.25”
Overall Diameter - 11”
Bolt Hole Circle - 10.125”
Motor Width - 6.25”
Motor Depth - 3.25”
Basket Depth - 2.75”
Displacement - .14 cu. ft.
Weight - 20 lbs.
Dual Composite 2-piece Cone
Rubatek Foam Surround
Cast Aluminum Basket
Tork-Tite Terminal
3" 4-layer Aluminum Voice Coil
FEA Optimized Motor Structure
Triple Stack Maganets
Progressive Spiders
Wrap around Rubber Gasket
Thanks
WOOFER #1
Fs(Hz): 35
Re(Ohms): 3.1
Le(mH): 3.0
Qts: 0.55
Qes: 0.60
Qms: 6.09
Vas(Liters): 15.8
Sd(cm2): 310
SPL(1w/1m): 82
Xmax(mm): 14
WOOFER #2
Mounting Depth - 6”
Motor Width - 6.25”
Motor Depth - 3.25”
Weight - 20 lbs.
Tork-Tite Terminal
Progressive Spiders
Thanks
