which amp?
I used to have a 83 ***** am and had 2 12" JL audio on a ***** *** crossfire amp and it was ridiculous. I suggest you get rid of your 2 subs get a qlogic box and get 2 quality dual 2 ohm subs subs with a mono block amp. My recommendation is go DIAMOND AUDIO, but im a little favoritist when it comes to Diamond if you cant tell
Im kinda lazy and don't feel like checking the specs on the amp, but they are both solid amps, kickers may be a bit better, but look and see how much power they are rated at, whichever has more use that one. As for the subs I don't like Comp VR's, but the Infinitys aren't anything to brag about either. I suggest you try both and decide which you like more.
99transam
99transam
MS
nosaj070
