Which Amp?
  • 2
Well on ike sound says Kicker C12VR4 Subwoofer 12" Dual 4-ohm Voice Coil Component Subwoofer...
so if Those are yours you can buy a Profile California CA800 $135 on ikesound.com that amp does 600rmsx1 at 4ohms so each sub wired to 8ohms in series and then both in paralell to 4ohms you´ll be receiving full 600rms. I think that the best you can do with $150....
hope that helps!
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
6
233
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
328
TwiztedRolla
TwiztedRolla
Sunrise, Fl
mamey69
Dan Medina
    Jun 17, 2024
Doxquzme
    Jun 15, 2024
