which amp
mustangmoe
im getting a w7 i want to have an amp that pushs it to its max while staying in the safe zone i was thinking about going with
MA HK4000D
RMS Power @ 14.4V: 50W x 1 @ 4 Ohm, 3600W x 1 @ 2 Ohm
RMS Power @ 17.0V: 75W @ 4 Ohm, 4000W @ 2 Ohm
Dimensions (W x H x D) 12.4" x 2.71" x 25.86"
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
2 Ohm Mono Stable
MA Audio HK802SX
1 x 4400W RMS @ 1 Ohm
2 x 2200W RMS @ 0.5 Ohm
2 x 800W RMS @ 2 Ohm
2 x 500W RMS @ 4 Ohm
Dimensions (W x H x D) 25.86” x 2.71” x 10.6”
Frequency Response: 10 Hz. - 350 Hz.
24 DB Variable low pass filter 50Hz-350Hz
24 DB Variable subsonic filter 20Hz-50Hz
Thermal, short, and overload protection circuitry
Full MOSFET circuitry
MA AUDIO HK-602SX
3,600 Watt 2 channel high current amplifier
1,800 watts RMS x 2 @ 0.5 Ohm Stereo
3,600 watt RMS x 1 @ 1 Ohm Bridged mono
RMS 2-Channel High Current Amplifier (High Current means more efficient power)
1,200 watt RMS x 2 @ 1 Ohm Stereo
700 watt RMS x 2 @ 2 Ohms Stereo
Digital LCD Display (Displays Voltage, Temperature & Output Level)
Platinum Plated Connections
Top Loaded Power & Protection LED
Thermal / Short / Overload Protection Circuitry
0-18 dB Variable Bass Boost
40-250Hz Variable High Pass Crossover
40-250Hz Variable Low Pass Crossover
Remote Bass Control
THD @ 2 0hm
S/N Ratio: >90dB
Channel Separation: 60dB
Frequency Response: 20-20kHz
Input Voltage Range: 200mV - 8V
Input Impedance: 10k Ohms
Dimensions (H x W x L): 2.7" H x 12.4" W x 23.4" L
THE SUB SPECS
JL W713 subwoofer
Specification
RMS Power Handling: 1,000 watts
4,000 Watts Max Power
3 Ohm Impedance
OverRoll Surround
W-Cone
Floating-Cone Attach Method
Plateau-Reinforced Spider Attachment
Radially Cross-Drilled Pole Piece
Massive Forced-Air-Cooled Aluminum Alloy Frame
Highly Linear, DMA-Optimized Motor System
Huge Diameter, Progressive Roll Spider
Co-Extruded Double Lead Wires
Ultra-Long Voice Coil
Frame Diameter: 14 in. (356 mm)
Mounting Hole Diameter: 11.9 in. (302 mm)
Mounting Depth: 10.5 in. (267 mm)
Overall Depth: 12 in. (305 mm)
Magnet Diameter: 8.38 in. (213 mm)
Pole Vent Clearance: 0.75 in. (19 mm)
Displacement: 0.21 cu. ft. (4.5 ltrs)
Sealed Range: 1.5 - 2.25 cu. ft. (42.48 - 63.72 ltrs)
Recommended Sealed Volume: 1.875 cu. ft. (53.1 ltrs)
Fc: 40.8 Hz
F3: 36.3 Hz
Qtc: 0.806
Ported Range: 2.0 - 2.75 cu. ft. (56.6 - 77.9 ltrs.)
Recommended Ported Volume: 2.375 cu. ft. (67.3 ltrs)
Recommended Tuning: 30 Hz
and with any of these amp will i be using 1ohm ?does it matter if its 1,2or3 channel im only using one sub
that amp will push it fine, but you'll probably end up crispying the sub, or some part of your electrical system if you dont do the big 3 and add a at least another battery. those are severe current hog amps. Trust me on this, ive had quite a few of them //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
thanks for the advice 1000\1 it is lol will i deff need anothwer bat with the big 3
even though im not going to push the system everday only when nessary is there anything else besides a 2nd battery im also looking for highs and maby mids nothing to crazy i just want to be able to here the voice when the sub is hitting
are PPi 356cs, Cerwin V- Max 65, Orion HCCA -6 which one you think is better for mids and if i get the mids will i deff need highs or if i get the highs can i use my stock mids and put highs up front i have an 07 camry
mustangmoe
mustangmoe
staten island n.y
mustangmoe
