Which amp would you use?
Okay - two DVC 4 Ohm drivers per one amp....right?
A pair of Dual 4 Ohm subs can only be run at 1 Ohm or 4 Ohm.
The 1st amp isn't 1 Ohm stable and will the 250w 4 Ohm output be enough for a pair of your subs? What kinda power do they want? I'm assuming more than 125w per...
The 2nd amp makes 500w @ 1 Ohm. Is 250w per sub sufficient?
The 3rd link is the same as the second so I don't know what third amp you were considering.
97splash
97 splash
97splash
Ruston
tojo
Mike Mccabe
