which amp will power these subs nice
monkeyman
I HAVE 2 12" SOUNDSTREAM RUBICON R-12SQ THAT RUN AT 600WATT RMS AND AM LOOKING FOR A SOUNDSTREAM AMP I COULD PURCHASE IN ORDER TO MAKE THESE PUPPIES HOP WHICH AMP WOULD YOU GUYS RECOMMEND PLEASE POST LINKS IF POSSIBLE SO I CAN CHECK IT OUT MY MAX BUDGET IS 200$ FOR THE AMP NEW OR USED DONT MATTER AS LONG AS IT WORKS LIKE IT SHOULD HERES THE LINK TO THE SUBS I HAVE ITS THE 2ND ONES DOWN THE LIST
http://www.lightav.com/car/soundstream/subs.html
Okay - your subs are rated for 600w RMS and according to the specs found on the page you linked to they have Dual 4 Ohm voicecoils.
So - you'll want an amp that makes somewhere between 1,000w and 1,500w at either 1 Ohm or 4 Ohms.
You might have to expand your budget a bit, fella...
While i'm at it and since you received an answer
1. They don't run at 600 watts, they can handle 600 watts reliably
2. I'm
3. Which I
4. It doesn't
5. Here's
6. They are
I wont even bother with punctuation. I think the HOP you should be looking for is this one...http://www.hop.com
monkeyman
monkeyman
los angeles,ca
Scoobydoo
AJ (ACE)
    Jun 28, 2026
