Which AMP should i go with these speakers?
camar0rs
Need help picking a good amp just for these 10 speakers, subs will have own amp...
with configuration below listed, would i go with a 4 channel amp tying the rear panels and hatch together or 6 channel amp all split ???
Headunit: Pioneer AVIC-8201NEX
Power Output:
Peak: 50 watts x 4 channels
RMS: 17 watts x 4 channels
Firebird has 10 speakers currently installed:
Door: 6.5" (JBL CLUB6520) + 1" Tweeter (JBL GTO19T)
Back Panel: 6.5"(JBL CLUB6520)
Hatch: 4"(JBL CLUB4020) + 1" tweeter(JBL GTO19T)
Speaker info:
JBL GTO19T - Tweeters:
Nominal Impedance3 ohms
Power Handling (Peak)135W
Frequency Response2.5kHz-21kHz
Power Handling (RMS)45W
Sensitivity(2.83V/m) 93dB
JBL CLUB4020 4":
Power Handling 30W RMS, 90W peak
Sensitivity (@ 2.83V)90dB
Impedance (ohms) 3
Frequency Response75Hz – 20kHz
JBL CLUB6520 6.5:
Power Handling 50W RMS, 150W peak
Impedance (ohms) 3
Sensitivity (@ 2.83V)92dB
Frequency Response55Hz – 20kHz
Nobody has answered since having 10 speakers playing stereo is dumb.
To do it right you will need 10 channels of amplification. A processor that can handle 10 channels plus the sub.
So a 12 channel DSP and I think there is only 1 or 2 on the market. Mosconi and Audison. Both are in the $1500 range. Then the amplifiers. Which will run into the $1200 range.
A better way would have been only fronts. Since music is only recorded in Left and right, not rear.
I assume he's just looking for a little bit clearer and louder
I don't think he's going to try and win any sq events
Going only front with separate channels for mid and tweet would get a good sound though and could be an option
You could also power rear speakers with the h/u for some rear fill
I assume he's just looking for a little bit clearer and louderI don't think he's going to try and win any sq events
Maybe. Or maybe he's like 99% of the people and just doesn't know what's possible with a simple nice setup that's planned right.
for front 6.5 comps and rear 6.5 coax, what would you say falls into this category? something along those Hi-Vis i asked about the other day? and something like a pc-450 to run them (maybe not even that big)
the car comes equipped with 10 speakers so i was going for clearer and louder only, not trying to do any comp stuff
amps will be mounted in flat hatch area, havent decided on building/buying a setup yet
I was already assuming doing a 4 channel with rear sets in parallel....
I spoke with JBL and they are recommending this amp : JBL GTR-104
thoughts?
camar0rs
camar0rs
orlando, fl
camar0rs
