which AMP is better ?!!
which be better for (2) DD 9512f dual 1ohm !??
  • Total voters
    15
i'd pick that DD up, then the Mmats. the hifonics is not a bad amp if you're on a budget but they have a tendency to overrate their amps.
I used the 2607d, and i'll vouch it does rated power. only reason im sellin it is because the new subs require a 2 ohm load //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The DD M3 is a very impressive amp and super efficient...SQ is some of the best you can get from a class D......It was designed to get class AB sound with class D efficency.....I've ran MMATS....Hifonics...and various other brands...but you can't beat the M3 if you want power and quality....
I have the MMats d.3500.1 and the amp kicks ***, it says 2700 watts RMS, bullsh*&, according to my 20 farad, tsunami hybrid cap, it is drawing at high volume aroung 260+ amps at 13.8 - 14.2 volts with a 250 amp alt from motor city. I recommend this amp to anyone. On ebay, there is a guy that sells them dirt cheap at around $750 which is half of the retail value. Get it, you wont regret it.
Mr.GoodGuy
Mr.GoodGuy
Houston, Texas, United States
eboutin88
vegang
vegang
