Which amp for mids and highs?
  • 6
audiobaun
2,149
USA
Question I have is..Which amplifier would be most suitable for running my mids and highs?
Have the AUTOTEK BTS 7204 -50x4 Bass Thrust,not the BTX-Blue/silver
OR
Have the Hifonics VII Gemini - 50x4
FRONT STAGE_-The amp will be at 2ohms in the front doors on 360rms 3-way seperates,and 1 set of 1in 100rms tweeters...
Possibly another set of 3/4in 50rms tweeters,as well as removing the 4in sub away from the seperates,and adding a 5.25 100rms mid
REAR STAGE_- Will consist of 1 pair of 6.5 200rms seperates
Subwoofers will consist of-2)10in dvc2ohm 1000rms,and 1)18in. dvc4ohm 1200rms,all at 2ohms mono,on 2 Hifonics Cyclopys VIII-100watt mono-1on the tens,and 1 on the 18
NEEDING HELP MAKING DECISION ..Any and all advice needed please..I thank you for your time.//content.invisioncic.com/y282845/emoticons/thankyou.gif.5451126d09e870f796f50c3a4dd5acd7.gif
Question I have is..Which amplifier would be most suitable for running my mids and highs?Have the AUTOTEK BTS 7204 -50x4 Bass Thrust,not the BTX-Blue/silver
OR
You dont need, or even want, multiple sized subs in your system.
You dont need, or even want, tweeters in the rear, if you are after SQ of any sort.
The rest of what you said was too confusing to decipher.
Why would nothing work with this setup,and why would it not sound good???What do I need to read as well? I only asked of which amp will be best for the mids and highs?? Not to slash me on my setup.Why do I not need different subs within my set up??Obviuosly I want to do itI think it will sound great!!,and as for the tweeters in the rear fill..I have them there now,and actually brought out a surround sound affect that I was searching for...Filled in missing stage affects,and sounds awesome!!I think when I complete this install...this will be one of the loudest,bass banging 400 watt system that i have ever heard.400 watts!!!This is going in a 98 xcab 3door truck..and all of it is installed,with exception of the 18,and 2 sets of tweeters,along with different amps,as of now I have the 4x35 Hifonics EuropiaVIII,and an Autotek 7150 BTS-150 watt on the subs-2)dvc2ohm at a 2ohm load,and sounds badd ***!!I am not asking of any bashing of what I have ,or what I intend to do with my system set up other than WHICH amplifier that you believe will sound best,on my mids,and highs,due to the same inventor of the amps,and specifications are quite close? I am simply asking of opinions of and get the best response of which amp to utilize.I always have had,and do get nothing but comments of my system,of loudness,clean clear sound,and of how the hell can i get all that power out of that (under 500 watts total of amps used).Nothing but jaw droppers??? So,I dont see how nothing will work,or needing to rethink of my setup/read???Read what??,as It is all working just F. I. N. E. ,fine????Confusing??I re read what was written,and looks to be quite clear to me????The amps being used are all 11.6v,and not the new amps that are in need of 14.4 to deliver the potential.JUST TRYING TO GET OPINIONS ON WHICH AMPLIFIER TO USE FOR MY MIDS AND HIGHS OF WHICH I HAVE AND WILL BE USING IS ALL THAT WAS ASKED OF??NOT TO BASH MY SYSTEM SETUP?THANKS GUYS
//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif:crying://content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Ch 1 and 2 can be bridged and 3 and 4. The amp shows you where to put the speaker wire to bridge it. It becomes a more powerful 2ch.
32
6K
85
332
  • Locked
640
Amp
471
audiobaun
audiobaun
USA
mylows10
    May 31, 2024
    May 24, 2024
