Which amp do I need for these memphis subs?
  • 2
oleblue
I have a dodge quad cab without much room under the rear seats. I'm don't know a whole lot about matching subs and amps. I am going with a fox acoustics box. It has 1.8 cu ft. of air space. I am going with 2 memphis s class shallow mount 10's. They are 4 ohm, DVC, 300 watts RMS. I can spend around $300 for an amp or more if need be. What is a good amp for this setup and should I go with SVC or DVC both are 4 ohms for the same price? I appreciate any help.
585
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
956
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
oleblue
oleblue
Arkansas
oleblue
    May 12, 2024
Brendon Jenness
    May 11, 2024
