Egor Rapoport
Hey guys,
I got 1995 mark VIII which has a stock 120amp alternator.
I am running Hifonics 100Wx4 amp for speakers and Memphis Mojo 4000W @ 1ohm for subwoofer. I also have an Optima Yellow Top battery.
Currently with stock setup my voltage would drop to 11-12V and my Hifonics amp would shut down.
I bought a high output alternator (mitsubishi). It is 220amps @ 1200rpm. problem is that when this alternator idles it gives 13volts @ 600rpm. Once you rev it up to 1200rpm it provides 14.4 volts as needed. Having this alternator improved voltage drops by it is still not very good.
I am also getting 2nd battery Optima red top to help voltage drops.
The guy who I bought high output alternator says that this is how ALL high output alternators work and i either need smaller pulley (which he cant find) or he is offering to take the alternator back and give me a refund.
Here is my question.
Do I:
A. Stick my stock 120amps under the hood which does do 14.4 volts at idle but less amps then stock
B. Keep 220amps alternator which does 13volts at idle but more amps then stock
Also, explanation would be much appreciated!
Thanks in advance!
Do I:
Thanks in advance!
