Which 12"?
fu or ab., fu plays low even tuned kinda high so if u want low i'd say fu.. xfl takes little bigger box from what peeps say sine u will have 2 if u have room for 4.5 or more cf u can get the ab is u wanta stay 3.4- 4cf get the fu.. other option for that $ is fu 1250 15, nice cone on those things..
Can the FU 750 take more than 1.5k daily? Does coil size matter? From the site it seems like a buffed 2.5 coil. I have a 03 acura cl so i guess the xfl are a no go?
idk your amp.. the xfl can take power i think that y kr said xfl idk.. my fu is deep but needs more than my amp at 2 ohm to be real loud fs..
no i wouldn't run 1500 to a 750.. 1500 or so to a 1250 sure..
Yea the 1250 would be a great option but out of budget. Just not sure if i have the trunk space for the xfl to sound ok.
I'm running a 18 in 7.5 net. In my Acura TL trunk. And I'm pretty sure the CL is bigger. So you should have plenty of room for 2 12s.
Dude I don’t even know how U can be giving advice... that fu woofer u have isn’t even being used close to its potential, you say it plays low but yet u prly don’t even know what low is. Low is like20- 15hz and actually playing it,... and just because U have the FU in one box you think that’s the way it sounds, you could build a different box and it could be a totally different sounding woofer. It’s annoying reading all the bad advice you give people
Im running on stock alt(big3) with a xs3400 infront and smsagm80 in back with a SD 2.5k can the sa12 handle that daily?
Clean power yes, I’ve ran four SA woofers on a dc 7.5k daily with no problems, and have had plenty of friends who have done he same... 2.5k amp will be nice on two SA 12s,
Sabbs
Sabbs
OK
bigblank69
    May 16, 2024
    May 16, 2024
