Wheres my tuning at?????
BassAddictJ
ok....internal dimensions 21.5L x 27.5W x 18.5H putting me in the 6.3ish cubs internally
4.5 inch x 18.5 = 83.25 square inches of port area.... port is 22.25in long (call it 22)
external deminsions are 23L x 29W x 20H
shitty ms paint ftl lol
and yes this is my old xxx 15 box, i just knocked out the 2 other baffles for more internal volume.....just curious bout my tuning....
if i shorten/widen/move that piece and move it ovr can i change the tuning to 30Hz?? the net volume just needs to be above 6 cubs??
correction on previous i that that was 6.3 gross not net
so tuning now is at a little over 35hz
getting to 30hz would either require you to take port down to 3 x 18.5
or
make the port 33" long which would porb take you under 6cubes
if what i add 2 pieces of mdf and go from 4.5in wide to 3in wide and add a piece to the back to make it 3in at the turn...woudl it be possible?
BassAddictJ
BassAddictJ
FL
NoRemoteNoTV
