Where to ground my amp?
pics of the metal nearby where your amp is?
do you have any sort of thick metal frame support that runs directly up to the front firewall of the vehicle without any major spot welds or other electrical inhibiting factors in the way?
you're only running a small load so its not going to be too picky imo
wire up the amp itself with remote and power wire. use your multimeter and set it to ohms. 200 setting i believe. take the positive lead and place it on the amps GROUND terminal. and then take the negative lead on the multimeter and place it anywhere in your trunk. try to find a spot that is thick metal and is close to 0 ohms. i happen to find that my seat belt bolt is pretty good for me at 0.3 ohms so i chose that spot.
IrishMike
IrishMike
Ohio
IrishMike
