where to get 80 amp fuse?
I used to run that type of fuse... I could only find 60A at autozone, dunno where to get larger ones. I did an install on a friends truck that used a 100A Maxi Fuse though so you should be able to find it SOMEWHERE.
MAXI fuses are pretty easy to get. Any audio shop that carries Stinger or Lightning audio or Streetwires should have them on hand or be able to get them quickly. They come from Stinger in packs of 3 so you have a few extras to keep around in case you blow one. If you are blowing fuses of the correct size, then you have other problems that need addressing, so don't just keep replacing them or move to a bigger size to keep them from blowing.
Thanks guys for the help. I ended up getting a 60 amp fuse at Straus for $3.97 (they were out of 80 amp fuses). Fuse was fine until I accidently let the power cable tpouch the body of the car (sparks aaaah!), but now it's rocking again.
WiNnErPL
WiNnErPL
nYc
helotaxi
