That's typically the result of a transcode, ie. the file is encoded at a certain bit rate, then re-encoded after that. Not good...I mean the thing is some of the ratings "say" 256 but that file could have been through alot of compression or whatnot...because ive heard some 320 sound like *** before
I don't think you can buy lossless through iTunes, but I could be wrong. I don't use it much.My girlfriend just told me she has a $25 gift card to i tunes. I created an account but now I am reading their tracks are 128? Whats this about Itunes Lossless? Anyone want to chime in?
If you have someone blocked, it has something similar to when a post is deleted that says something like: this post is blocked because ------ is on your block list. It also allows you to click on open post to see it anyway if you want to.so how did you see it?
take notes, see my sig //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifX2 Quit Fucking Talking!
Yes...you can't? Only lossy compressed formats that I have heard that come close are OGG at the highest bit rate and lame encoded 320...I usually have FLAC copies for critical listening //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifCan you really hear the difference between .wav and 256kbps?
it says somethin like "blah blah is on your blocklist"so how did you see it?
well then I **** at the internet, and im not cool enough.if you can't find cd quality torrents then you FAIL horribly at the internet.
or you're just not cool enough to get into private tracker sites..
Thanks for your input..I think im going to try usenet.That's typically the result of a transcode, ie. the file is encoded at a certain bit rate, then re-encoded after that. Not good...
All my downloads are full FLAC albums with logs and cue sheets from private sites (ie. Waffles and What). You can have pretty good luck if you go with usenet as well.
yepIf you have someone blocked, it has something similar to when a post is deleted that says something like: this post is blocked because ------ is on your block list. It also allows you to click on open post to see it anyway if you want to.
