Where to buy headunit removal keys?
I need removal keys for an Eclipse CD3000 and an Alpine CDA-9887, where can I buy these? the CD3000 keys are DEFINITELY not on ebay, and the 9887 doesn't seem to have any that would work for it on there either.. any suggestions?
me and my dad made my own out of sheet metal.
search for basic alpine / eclipse keys
most manufacturers use basic keys for all headunits
or pull the entire thing (including the metal case for the HU) and just use a screw driver/your fingers to put it out.
If its in a standard cage type deal you should be able to put a small thin screw driver or thin metal object down the sides and pop the cage out away from the HU and the HU should slide out from there. I've never heard of a key other than for the 99-04 Ford HU's.
Best of luck at worst case you can disassemble the dash and pull out the dash kit and cage and then seperate the HU from the cage from there.
i know on my Pioneer I have the keys that you're supposed to slide in to take the deck out but numerous times I've just taken my key to start my car and a quarter on the other side and just pulled on each side individually til I could pull it out by myself. You don't need keys.
Phlipbak
CA Enthusiast
Phlipbak
Dothan, AL; Nashville, TN
SRim23
