Where to buy CROSSOVERS???
Kastlez_
Running Digital Designs Audio DDA-T28 Tweeters and would like some crossovers to protect them.
SPECIFICATIONS
Frequency Response 1500 Hz to 30 kHz
FS 800 Hz
Nominal Impedance 4 Ohm
Power Handling 150W RMS
SPL 1W, 1m 91dB
Voice Coil Diameter 28mm
1500-2khz Crossovers are what i'm looking for based on the specs.
LINKS APPRECIATED!
thanks
Ive never had an issue running inline crossover capacitors on tweeters and running the mids full range on a 80hz HP. Not sure if that would please the SQ gods but ive put together some very clean sounding setups like that.
You can get them on parts express for any band you need for about 2$ each. They also sell 2 and 3 way crossover networks if youre looking for something like that. The "infiniti" 2 way crossovers they have are VERY nice. They dont come with a case or anything so you have to solder the leads. I assume they would come with some high end home audio speakers or something, but they are a nice piece. Ive put together many "sq" favored 2 and 3 way setups with the infiniti crossovers and they sound a bit better than just running the cap crossovers.
They also sell blank pcbs and the components to build your own...that's what I did. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Kastlez_
Kastlez_
Bay Area, CA
Redlineaudio
