where can you buy these at?
Never bought any for a Honda, always used coilovers. But the cheapest ones i was able to find for mustangs where from Autozone. We usually change them when we filled the hatch with stereo in the fox body cars('87-'93).
well if the coilovers are a little too pricey then i guess i can always go there and ask about some stiffer springs...
If you get those cheap *** coilovers off of ebay most will lower it an inch set to the maximum heigth, do a search in the yellowpages for spring places around your town. There is a shop across town from me that is pretty knowledgeable. They can custom make springs, dearch leaafs, lower, lift, they do cars, trucks, big rigs, motorcycles, atv, whatever. There are shops that specialize in it.
kyb and edelbrock both make an adjustable shock ( coil over ) for racing and they work well also.
what do custom springs normally cost u have any idea?
THE kyb shock r they to just raise the car or carry more weight
someone told me they aren't made to carry the extra weight r they wrong? bcuz kyb shocks r on ebay
i wouldn't go with coil overs if you plan on raising the rear. for a good coil over set you'd be looking at spending well over a grand.
some spring manufactures can most likely custom make you some springs that you could use to replace the oem ones you have with a stiffer/stronger spring compression rate. i can't think of any company names atm but they make lots of custom suspension stuff.
michaellane
michaellane
tx
Loud3
