where can i get 8awg wire nuts?
Why would you want to use wire nuts on 8awg?
For any circuit with that much current going through it, please, do yourself a favor and use a proper connector with good mechanical strength.
Wire nuts are excellent for connecting solid wires in things that don't move much, like houses. The are not such a good idea for stranded wires in moving vehicles. If you don't feel like soldering, use a butt connector.
ok its for an hd12, i need closed end connectors i guess then...
some webpage had those listed as wire nuts but it looked like this a wire nut
If you need to connect multiple wires like that in a vehicle, please...use a terminal strip with jumpers to connect the screws. You can find something like that at PE or Radioshack...would be the much safer way to do it.
skmfkr
skmfkr
Savannah, GA
Raven
