where can i buy a adire audio sub
I have a MK3 running off 600 watts and I love it had no problems yet had it for a little over a month and a half...I think alot of the Failures are from people pumping 1000-1600 watts to them. The new drivers only need 600-800 watts thats it anymore is just burning it up. Not trying to defend Adire but just tell you guys my experience.
Any ideas what the MKI will handle? I'll be trading a reconed MKI from two years back that has no play on it for an Eclipse deck of mine and was wondering what the max amout of power I should give it.
Believe it or not the new Brahma is a great low power driver 500-800 watts no doubt about it. It gets loud and has a very clean sound you just can't over power it and from what I read you have to be carefull don't jolt the box around alot or the motor will miss align... That problem should of been taken care of with the new MK4's tho.
MK1 should take 1600 watts from what I gathered but I have never used one so I can't tell you what it will handle.
Believe it or not the new Brahma is a great low power driver 500-800 watts no doubt about it. It gets loud and has a very clean sound you just can't over power it and from what I read you have to be carefull don't jolt the box around alot or the motor will miss align... That problem should of been taken care of with the new MK4's tho. MK1 should take 1600 watts from what I gathered but I have never used one so I can't tell you what it will handle.
The new brahmas weren't worth the boxes they came in:verymad:
I agree they should of never released them using the spacers bad idea. Also the new brahma shouldn't be called that because it isn't in the same league as the old ones. I never heard a Brahma but I have played with a XXX and the XXX is alot better then the new drivers. But jizm you have to agree a driver that can sound good and get pretty loud withh 500-800 watts is a good idea.
Adire went downhill when the stopped using other people's subwoofers. (i.e.: eminence, destijl...)
Heh.
nG
fuimalexis
fuimalexis
Orlando, Fl
AVA
