where am i going wrong?
ehh..i loved em, you should have seen the stares i got when i had them,only abd thing got pulled over about 5 times with them and since only once
alright finished drawing it up....do these number sound about right?
side= 15.25"x18.5"
top and bottom=19"x34.5"
back=33"x15.25"
front= 33"x13.25"
port 1=33"x15.5"
port 2=33"x5"
i hope that sounds right....
uh...I really dont know without knowing how you want your pieces to fit together...Its all on you to make sure your final numbers are right. Measure 3 times, cut once. good luck man.
EDIT:eek:k, about the first port wall...I assumed the port wall was to be placed behind the baffle so the .75" was already taken into account. If its to be mounted with the baffle then ADD the .75"
So If you want to place it behind the baffle, return the first port wall value to 16.25", if you want it next to the baffle then it needs to be 17"
EDIT: wait a second...what is the outer depth dimension?
Your box, according to page 1, is to be 19" deep correct? Making the inside depth 17.5". Thus you were correct in your first port wall measurment of 15.5". I was mistaken earlier, It was late and I did it all in the dark, lol. And my original calculation for the second wall was correct of 5.75", lol. So in conclusion (lol), The first port wall length should be 15.5" and the second would be 5.75"
eric12421
eric12421
RI
j3bus2k3
