When wiring remote wires can I splice them together?
I have 2 amps. Can I splice/solder them together and run 1 power wire into the solder for both remotes? will that hurt anything?
I don't quite understand the question regarding the power wire.
But you can daisy chain (connect the remote to one amp, then connect another wire to the remote clamp on that amp and run it to the other amp, or you can splice the wire and make it Y.
Don't splice it. Run the remote wire into one of the amps, then run another remote wire from the 1st amp to the other one.
You realize you're doing the same thing if you splice it or daisy chain...?
As long as you solder it properly, it'll be fine.
Glock23
Glock23
il
IDSkoT
