when running comps...?
blackbonnie
The Revolution
when you run comps passive do you turn all filters on your amp off, or to full. instead of using HPF or LPF would you turn your filters to full or off due to the fact that the crossover already filter out certain frequecies or have i not thought this through fully. i was just pondering this during work but i may have thought about this in to hard of way and its actually real simple. but either way i would like to clear this up for me and others who have had this questions
You still run a HPF from your amp. The passive crossover with the comps only filters out certain freq to go to the tweeter and woofer. You still have to provide a highpass going to the passive to prevent low freq from getting to the comps.
I think its more of a preferance thing
I run my amp on full range and let the comps crossover do the work
for the most part comps are full range, they just cant produce low hz to well
(well most atleast)
blackbonnie
The Revolution
blackbonnie
Grand Rapids, MI
tee
michigan born
    May 14, 2026
michigan born
    May 14, 2026
