when running an 800prs active (std or nw)
Nope. When the deck is in network mode you only have the 3 pair of RCA outs. You cannot use the internal amp as another channel when running active.
Yes you can. Only difference is the speaker outs will become the same signal as the pre-outs......front=high, rear=mids. Unless you go into the settings and turn the amp off, you can use the speaker outputs. They just wont be full range anymore.
did the unit come with a user manual?
does anyway have a write on goin active with an 880? Do I just switch it to three way, or what. As soon as I get my wire I'm putting everything together.
If someone makes a write up for goin active with an 880 that would be awesome:D
so when running it active, my front rca's will go to my channels running the highs, and my rear rca's will go to the channels running my mids?
but how will i run that since i will have my highs on channel 1,2 and my mids on 3,4.
will i just run a splitter off my rca's or what?
I think you're asking for trouble with this whole thing. You can use a splitter but why use a different set of subs? Why not just use your subs all the time? This doesn't make much sense and you're just going to end up making your system more complicated.
those subs are for the when i have the world beater off...
im not sure on them yet, it has just been a thought. nothing is set in stone except what i already have
blackbonnie
The Revolution
blackbonnie
Grand Rapids, MI
Megalomaniac
